sensor-server
Device Config Commands
Configures an AirDefense sensor server resource for client terminations and WIPS event logging. This is the server that supports WIPS events on behalf of the controller or service platform.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
sensor-server <1-3> ip <IP/HOSTNAME> {port [443|<1-65535>]}
Parameters
sensor-server <1-3> |
Sets a numerical index to differentiate this AirDefense sensor server from other servers. A maximum of 3 (three) sensor server resources can be defined. |
ip <IP/HOSTNAME> |
Configures the AirDefense sensor server‘s IP address or hostname
- <IP/HOSTNAME> – Specify the IP address.
port [443|<1-65535>] |
Optional. Configures the port. The options are:
- 443 – The default port used by the AirDefense server. This is the default setting.
- <1-65535> – Manually sets the port number of the AirDefense server from 1 - 65535
nx9500-6C8809(config-device-94-9B-2C-13-3E-1C)#sensor-server 1 ip 172.16.10.7
nx9500-6C8809(config-device-94-9B-2C-13-3E-1C)#show context
ap505 94-9B-2C-13-3E-1C
use profile default-ap505
use rf-domain default
hostname TechPubAP505
floor 5thfloor
layout-coordinates 1.0 2.0
license AP aplicenseley@1234 aplicensekey@123
rsa-key ssh rsa-key1
location SanJose
no contact
country-code us
channel-list 2.4GHz 1,2
override-wlan test vlan-pool 8
mac-name 94-9B-2C-13-3E-1C 5.8TestAP
neighbor-info-interval 50
Related Commands
no |
Removes configured sensor server settings |
